Очистные сооружения больницы: особенности эксплуатации
Hospital Treatment Facilities: Specifics of Operation
M. M. Pukemo, Ph. D. (Engineering), Associate Professor, MIREA – Russian Technological University, Member of the Expert and Technological Council of RAWW, Chairman of the Board of Directors of Alta Group; A. A. Kulakov, Ph. D. (Engineering), Associate Professor, MIREA – Russian Technological University, Member of the Expert and Technological Council of RAWW; R. V. Zheltukhin, Senior ACS Engineer, Alta Group
Keywords: treatment facilities, hospital wastewater, additional substrate, sucrose, denitrification
Hospital operations produce large amount of waste, including biological waste, hazardous for human health and the environment. Foremost, this relates to sewage effluents. Hospital wastewater is characterized by high concentrations of nitrogen at the treatment plant inlet with low COD and BOD values (BOD/nitrogen ratio can reach 1). Wastewater treatment facilities with nitrogen removal are designed with consideration of deep oxidation of ammonia nitrogen (nitrification) and recovery of the produced nitrate nitrogen (denitrification). However composition of wastewater coming for treatment, as is common with hospital wastewater, doesn't always allow for traditional technological solutions for nitrogen compounds removal. This article looks into specifics of operation of hospital treatment facilities using Moscow Clinical Center for Infectious Diseases "Voronovskoye" as an example.
В результате деятельности больниц образуется большое количество отходов, в т. ч. биологических, опасных для человека и окружающей среды. В первую очередь это относится к канализационным стокам.
Сточные воды больниц характеризуются высокими концентрациями азота на входе в очистные сооружения при низких значениях ХПК и БПК (соотношение БПК/азот может достигать 1). Канализационные очистные сооружения с удалением азота проектируются с учетом глубокого окисления аммонийного азота (нитрификация) и восстановления образующегося нитратного азота (денитрификация). Однако состав поступающих на очистку сточных вод, как в случае со стоками больниц, не всегда позволяет применять традиционные технологические решения по удалению азотных соединений.
В данной статье рассматриваются особенности эксплуатации очистных сооружений больничного комплекса на примере МКЦИБ «Вороновское».
Статья опубликована в журнале “Сантехника” за №6'2021
