Влияние характеристик материала фильтрующей загрузки на эксплуатационные параметры фильтров водоочистки
Influence of Characteristics of Material of The Filtering Loading on Operational Parameters of Filters of Water Purification
V. V. Dzyubo, Doctor of Technical Sciences, Professor at the Department of Water Supply and Wastewater, FSBEI HPE Tomsk State University of Architecture and Building
Keywords: the filtering material, technical characteristics, fineness, grain form, porosity, contaminant capacity of material, filtering process parameters, filtering speed, filter run duration
Widespread types of the filtering materials and their technical characteristics are given in article. It is shown that the filtering material as technological structure, is characterized by a number of the parameters influencing both parameters of work of filtering constructions, and efficiency of process of purification of the conditioned natural waters, changing which it is possible to predetermine both parameters of work of constructions, and quality of the cleared water depending on its initial quality, and at design of filtering constructions it is necessary to determine the most economic parameters of the filtering material correctly: height of a working layer of material, fineness and heterogeneity of fractions, formal speed of filtering for the guaranteed achievement of the demanded quality of the cleared water. On the basis of pilot studies it is shown that reduction of fineness of fractions of the filtering material allows to increase filtering speed at preservation of quality of the cleared water and, respectively, productivity of filtering constructions thanks to the raised specific surface of grains of material, despite increase in resistance of loading and losses of a pressure on it.
В статье приведены распространенные виды фильтрующих материалов, применяемые в целях водоподготовки и их технологические характеристики. Показано, что фильтрующий материал, как технологическая структура, характеризуется рядом параметров, влияющих как на параметры работы фильтровальных сооружений, так и на эффективность процесса очистки обрабатываемых природных вод, изменяя которые можно предопределять как параметры работы самих сооружений, так и качество очищенной воды в зависимости от ее исходного качества, а при проектировании фильтровальных сооружений необходимо корректно определять наиболее экономичные параметры фильтрующего материала: высоту рабочего слоя материала, крупность и неоднородность фракций, формальную скорость фильтрования для гарантированного достижения требуемого качества очищенной воды. На основании экспериментальных исследований показано, что уменьшение крупности фракций фильтрующего материала позволяет увеличивать скорость фильтрования при сохранении качества очищенной воды и, соответственно, производительность фильтровальных сооружений благодаря повышенной удельной поверхности зерен материала, несмотря на увеличение сопротивления загрузки и потерь напора на ней.
Статья опубликована в журнале “Сантехника” за №1'2019
